There is a TSB or several out there, maybe the Dealer will foot the bill,
Van E350 TBS Fuel Tanks from Ford Info:
2000 FORD E350 Recall ID from NHTSA: 01V114000
Auto Recall Date: 20010405
Vehicle Component: FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY
Estimated Vehicles Affected: 151000
2000 FORD E350 Defect Summary:
VEHICLE DESCRIPTION: ON CERTAIN VANS WITH AMBULANCE PREP PACKAGES OR OTHER SEVERE-DUTY APPLICATIONS INVOLVING OPERATION AT OR NEAR THE GROSS VEHICLE WEIGHT WITH FREQUENT TWISTING OF THE VEHICLE BODY, SUCH AS OFF-ROAD, ROUGH ROAD OR SPEED BUMP EVENTS, THE 35 GALLON MID-SHIP FUEL TANK COULD DEVELOP A CRACK WHERE IT CONTACTS THE FRAME CROSS MEMBER. IF THE FUEL TANK CRACKS, FUEL LEAKAGE COULD OCCUR.
Defect Consequence:
FUEL LEAKAGE IN THE PRESENCE OF AN IGNITION SOURCE COULD RESULT IN A FIRE.
Remedy:
DEALERS WILL INSPECT THE FUEL TANK AND, IF CRACKED, WILL REPLACE THE TANK. INSULATOR PADS WILL BE INSTALLED ON ALL VEHICLES TO REDUCE THE STRESS LEVELS IN THE FUEL TANK. OWNER NOTIFICATION BEGAN APRIL 19, 2001. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT FORD AT 1-800-392-3673.
Notes: FORD MOTOR COMPANY, 01S14
2000 FORD E350 Recall ID from NHTSA: 00V284000
Auto Recall Date: 20000921
Vehicle Component: EQUIPMENT:OTHER:LABELS
Estimated Vehicles Affected: 4500
VEHICLE DESCRIPTION: BI-FUEL CNG PICKUP TRUCKS AND BI-FUEL CNG VANS, MODIFIED BY CFI CONTROL SYSTEMS, INC., FAIL TO CONFORM TO THE REQUIREMENTS OF FMVSS NO. 303, "FUEL SYSTEM INTEGRITY OF COMPRESSED NATURAL GAS VEHICLES." THE LABEL AFFIXED TO THE FUEL FILLER DOOR BY THE VEHICLE MODIFIER CONTAINS THE INSPECTION DATE AND EXPIRATION DATE OF THE CNG TANK. HOWEVER, IT DOES NOT CONTAIN THE STATEMENT "SEE INSTRUCTIONS ON THE FUEL CONTAINER FOR INSPECTION AND SERVICE LIFE."
Defect Consequence:
THESE VEHICLES DO NOT COMPLY WITH THE REQUIREMENTS.
Remedy:
OWNERS WILL BE PROVIDED A LABEL WITH THE REQUIRED STATEMENT, ALONG WITH INSTRUCTIONS FOR AFFIXING THE LABEL AT THE FUEL FILLER DOOR. OWNER NOTIFICATION BEGAN NOVEMBER 2, 2000. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT FORD AT 1-800-392-3673.
Notes: FORD MOTOR COMPANY, 00L07
2000 FORD E350 Recall ID from NHTSA: 00V115000
Auto Recall Date: 20000419
Vehicle Component: WHEELS:LUGS/NUTS/BOLTS
Estimated Vehicles Affected: 3300
VEHICLE DESCRIPTION: CUTAWAYS AND STRIPPED CHASSIS WITH SINGLE REAR WHEELS. THE LUG NUTS CAN POTENTIALLY BOTTOM OUT ON A SHOULDER ON THE STUDS.
Defect Consequence:
IF THIS OCCURS, THERE CAN BE AN INADEQUATE CLAMP LOAD TO ATTACH THE WHEEL TO THE AXLE, RESULTING IN NOISE, DAMAGE TO THE WHEEL AND HUB, OR IN EXTREME CASES, LOSS OF A REAR WHEEL WHILE THE VEHICLE IS BEING DRIVEN.
Remedy:
DEALERS WILL REPLACE THE REAR WHEEL ATTACHING STUDS.
Notes: FORD MOTOR COMPANY, 00S08
2000 FORD E SERIES Recall ID from NHTSA: 03V094000
Auto Recall Date: 20030307
Vehicle Component: STRUCTURE
Estimated Vehicles Affected: 3674
2000 FORD E SERIES Defect Summary:
CERTAIN PICKUP TRUCK, VAN, AND MINI VAN CONVERSIONS EQUIPPED WITH SOUTHERN COMFORT BUILT RUNNING BOARDS THAT CONTAIN CERTAIN COURTESY LIGHTS MANUFACTURED BY AMERICAN TECHNOLOGY COMPONENTS, INC. THESE UNITS CONTAIN A COURTESY LIGHT OR LIGHTS THAT MIGHT OVERHEAT WHEN THE WIRE HARNESS IS EXPOSED TO EXCESSIVE MOISTURE AND ROAD SALT.
Defect Consequence:
THIS OVERHEATING CONDITION CAN CAUSE THE RUNNING BOARD TO MELT OR CAUSE A FIRE.
Remedy:
DEALERS WILL REPLACE THE WIRING HARNESS ON THESE RUNNING BOARDS. OWNER NOTIFICATION BEGAN MARCH 7, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT SOUTHERN COMFORT AT 1-800-745-6096.
Notes: SOUTHERN COMFORT CONVERSIONS,
