Just installed a Transfer Flow 75 Gallon Aux Tank with Trax II. Noticed I had a slow fuel leak. I removed the skid plate and noticed that I had a drip on the bottom of the forward tank. Once I touched it, it became a steady stream!! Although small, but still dumping fuel. I pumped out the tank, cleaned and dried the leaking area, applied an epoxy based tank repair...About $4.00 for a stick, for metal tanks, and it will not hold?? What is the best way to fix this, other than replacing the tank, for "Peace of Mind"...Also, I will undercoat the tank before putting the skid plate back on, any suggestions on what to use for that as well?.
