1 - 10 of 10 Posts
I need some recommendations on gauges. I'm tempted by Edge's solution, but I hear it's not as accurate as standard gauges. It's also a little more upfront. Any thoughts? Thanks
This is the New Edge Insight the one i have they no longer make
http://performancetruckproducts.com/edge-insight-cs-fits-1996-and-newer-obdii-enabled-vehicles.html
or this is the one that i would get bigger is better but if i got it my wife would kill me
http://performancetruckproducts.com/edge-insight-cts-fits-1996-and-newer-obdii-enabled-vehicles.html
The pyro, that is a must if you pull or not
http://performancetruckproducts.com/edge-egt-accessory-for-cs-and-cts-non-expandable.html
This is a great tool plus it is plug and play
2 stroker:ford:
The Edge Insight is a good way to go. I've never heard of an accuracy issue. It's as accurate as the sensors used by the PCM to control the truck.
If you want to go a little cheaper route, check out the ScanGauge2. Pretty cool little device and very affordable.
Thanks for your input. I like the edge but have a hard time shelling out 400 for the monitor and not getting the tuner. Might just wait to buy the edge till I can afford both.
If you think 400$ is a lot then just add the tunes better have some deep pockets.
2 stroker:ford:
What he said...
Thats what i'm sayin.
Edge insight Is a great design. If y wanted to go with gauges, in my opinion the gauges that change colors are pretty expensive. I know u can get cool gauges wrapped in chrome built for semis.
1 - 10 of 10 Posts
