does anyone know the correct way to remove and install a gearbox on a 99 f350. any tips would be appreciated. thanks in advance.
There are a couple of gotchas in removing the transfer case, so I'll included the words from that section too:workshop manual said:1999 F-Super Duty 250-550 Workshop Manual
SECTION 308-03B: Manual Transaxle/Transmission — ZF 6-Speed
REMOVAL
Transmission
Special Tool(s) Transmission Jack
014-00942
All vehicles
1. Remove the four screws and the outer shift lever boot.
2. Remove the upper gearshift lever.
3. Remove the lower shift lever boot.
4. Remove the lower gearshift and shift housing.
Vehicles with a manual transfer case shift lever
5. Shift the transfer case into 4H.
6. Remove the screws that attach the bezel and boot assembly to the floor.
7. Remove the bolt that attaches the shift lever to the transfer case control lever assembly, and remove the shift lever, and the bezel and boot assembly.
..Slide the bezel and boot assembly upward on the shift lever.
.. Remove the bolt, the shift lever, and the bezel and boot assembly.
All vehicles
8. Raise and support the vehicle. For additional information, refer to Section 100-02 .
9. If the transmission is being disassembled, drain the transmission fluid.
10. Remove the starter. For additional information, refer to Section 303-06B .
11. Disconnect the rear driveshaft and position it aside. For additional information, refer to Section 205-01 .
12 Remove the transfer case, if equipped. For additional information, refer to Section 308-07B .
13.Remove any power take-off (PTO) equipment, if equipped.
14.Using the special tool, support the transmission.
.. Securely strap the jack to the transmission.
15. Remove the transmission mount nuts.
16. Remove the RH crossmember nuts.
17. Remove the LH crossmember bolts.
18. Disconnect the reverse lamp switch electrical connector.
19. Disconnect wiring harness from the transmission.
20. Remove the clutch slave cylinder and position it aside.
..Push the clutch slave cylinder inward, then rotate counterclockwise 45 degrees to remove.
21. Disconnect the transmission cooling tubes.
22. Remove the dust cover bolts.
23. Remove the transmission-to-engine bolts.
..For vehicles equipped with diesel engines, remove six bolts.
24.Remove the transmission.
..Move the transmission rearward until the input shaft is clear of the clutch, then lower from the vehicle.
Torque specs for the tansfer case. No, I'm not going to spend an hour trying to align the columns.workshop manual said:1999 F-Super Duty 250-550 Workshop Manual
SECTION 308-07B: Transfer Case
REMOVAL
Transfer Case
Material
Item................................................. Specification
Metal Surface Cleaner F4AZ-19A536-RA WSE-M5B392-A
All vehicles
NOTE: Shift the transfer case to 2W HI.
Remove the four bolts and the skid plate, if equipped.
NOTE: Index-mark the driveshaft to maintain driveline balance.
Remove the rear driveshaft. For additional information, refer to Section 205-01 .
Index-mark the front driveshaft to the transfer case flange.
NOTE: Support the front driveshaft with wire or a strap.
Remove and discard the four bolts and position the front driveshaft aside.
Manual shift transfer case
Remove the manual shift linkage, if equipped.
Disconnect the switch electrical connector. Position the wire harness aside.
All transfer cases
If disassembly is necessary, drain the fluid into a suitable container.
Install the plug when finished.
Position a suitable high-lift jack under the transfer case and secure it with safety straps.
All vehicles
Remove the six transfer case-to-transmission bolts.
Separate the transfer case from the extension housing. Pull the transfer case rearward, then lower the transfer case from the vehicle.
CAUTION: Carefully clean the gasket surfaces. Nicks and gouges cause fluid leaks.
Remove the transfer case-to-transmission gasket. Clean the mating surfaces, using metal surface cleaner.
Torque Specifications - Transfer Case
Description Nm lb-ft
Transfer case control lever assembly bolts 115 85
Shift lever-to-control lever assembly bolt 28 21
Sector support 31 23
Poppet screw 20 15
Case bolts 31 23
Case bolts at dowel 24 18
Front output nut 223 165
Rear output nut 251 186
Shift lever nut 20 15
Shift motor bolts 20 15
Three position indicator switch 27 20
Drain and fill plugs 27 20
Transfer case mounting bolts 50 37
