· Vendor
Grille guards are sought-after accessories because they offer the rare combination of a significant boost to the truck's looks and the addition of valuable protection against front-end damage on job sites, off-road trails, and other tricky situations. If you're looking for such protection, consider a grille guard from SteelCraft.
This grille guard is designed with frame-mounted upper brackets for maximum support. This accessory is going to give your truck an aggressive look and keep you and your passengers protected. The SteelCraft grille guard looks like a true OEM product, not as an afterthought one-size-fits-all accessory. It'll last the life of your truck or longer.
Buy Steelcraft products with 5% OFF the original price from now through May 8, 2022. Hurry up, do not miss out on this great offer! Prices are already reduced.
SteelCraft® - Grille Guard
Features:
  • Heavy-duty one-piece construction
  • Protective rubber stripping
  • Pre-drilled holes for auxiliary lights
  • Removable headlight covers
  • Frame-mounted upper brackets for maximum support
  • Available in stainless steel and black powder coat finishes
  • Easy Installation
