Bought the truck 17 months ago. GP History unknown. All of the old were BERU.
While replacing all 8 GPs with ZD-11, I found #3 GP very heavy with carbon on the sleeve (not the element). The other 7 were clean (photo).
Threads are good and the new GP snugged to 14 ft-lbs solid.
It Ohms fine.
Suggestions?
Bad Injector o-ring?
Discussion Starter #2
The carbon build-up extends up above the threads. This makes me think it might have come loose at some point in the hole.
It did not feel loose as I started to untighten it but I think the carbon had seized the threads.
Sound reasonable?
I think it must have not been torqued properly when installed. I can't think of anything else that would allow carbon to deposit up to and including the threads.
Discussion Starter #4
Glow Plug Carbon Build-Up
Thanks RT !
Always good to get your insight.
I'd agree it wasn't properly installed. They seal at that shoulder down near the tip. I suppose it's also possible there was a defect in the sealing surface (tapered seat).
Discussion Starter #6
Thanks Kevin,
I think I will pull the valve cover and check it at around 2,000 miles.
