need to confirm 83-86 f250 6.9 glowplug relay wiring diagram.
2BIG posts
on one side is battery power from starter
the other is output to glowplugs
2SMALL POSTS
one side is from ignition (white)
the other side to ground??
is this relay conected to starter solinoid anywhere?
my prob is that this is in a 1979 f250 which was running 100% top shape untill i loaned it to my brother 2 mos. ago. just got it back with all glo plugs fried. went to ford bought new plugs, relay, controller. put plugs and relay in so far. when i turn the ignition, light illuminates for about 4 sec then goes off, then on again for 1 sec about three sec later. is this correct or is my wiring screwed up or do i need to install the new controller.
any and all info greatly appreciated, thanks in advance.
2BIG posts
2SMALL POSTS
