Was wanting to convert from manual fuel pump to electric never done this before was wanting to know were to wire it up to work off the switch it's a 83 f250 6.9 any other advice would be helpful thanks
Hello buddy,
so you want to get rid of the old mechanical pump... good choice,
Im doing the same here with mine, I just bught a FACET (made in the USA) pump, model 40106.
let me know your progress in this install, I will wire mine from the shut off selenoide to a relay, and also a secondary toggle switch so I can prime the sistem before a startup, just as you do in an aviation setup (fuel injected planes) this will assure positive starts with little cranking and aid in r+r fuel filter also
