So after replacing a turbo and removing the cab I now have an issue where I have a hard brake pedal and when you turn the wheel it sucks the pedal in and applies the brakes.
Things I have checked:
-the inlet and outlet lines going into the booster are not reversed
- the pedal lowers and then returns slightly when the vehicle turns on like it should
- I have bled the system and the power steering is no longer whining
-correct fluid levels
- shaft going from pedal into booster is level
