I'm working on my 2001 7.3. I just replaced the windshield due to a water leak and I'm not sure what the water got into under the dash. I'm not sure if these two problems are leak related or not. I have read numerous post and need some guidance.
1. Fuel gauge goes to full when key is on. All post I found said to replace tank sender. Could this be leak related, PCM maybe???
2. GPR - Small terminal, red wire. There's .88 volts with the key off and wire disconnected. It should be zero. Again, could this be leak related, PCM maybe???
Any suggestions and guidance on what to do to correct these problems would be greatly appreciate.
Sam
Sam
