Thank you to the welcoming committee.
I have a 2000,F350,CC,7.3ltr. Super Duty and I am looking to download wiring schematics to help troubleshoot a short in the fuse8 circuit for the parking lights.
I found a forum posting where a member (woodnthings8) did an outstanding job of pasting together a wiring diagram for the engine schematics, and I would like to know if it is possible to send him a message to see if he has developed the schematics for the chassis electrical system .
I'm right here. You need a few posts before you can PM someone. Post up on other threads and you can sedn PM's.
What are you needing?
Thanks for responding ,Ken,
I was impressed with the schematic you designed for the engine in your 2002 truck. Have you prepared one for the chassis electrical system?
Is it available on line?
Is it the same for the 2000 F350?
If you have not prepared such a schematic ,where could I find the individual diagrams so I can cut and paste them myself?
My symptoms are: The Power Distribution Box fuse 8 keeps blowing when the light switch is rotated to the park light position.
There is no power to fuses 1 and 3.
No parking or marker lights
If you like you can email me at. [email protected]
Regards
Lawrence
Regards
Lawrence
Be careful because lots of difference on the electrical side append between 01 and 02. you should also post a new thread with the problem you have and will have way more view from people so more answer for your problem
cheers
Thanks Yan7gin,
Before I post a new request I want to follow the best lead I have found. Then I will try to scan all the forum posts already out there, since someone else has probably had my problem. If that does not work then I will try a new post. I started looking at over 1000 pages of postings, and could not find the diagrams I need. Yet.
