Where would a safe place to ground a wire be in a panel behind the parking break on a 2008 f450?
Andrew 1 · Registered Joined 11 mo ago · 18 Posts Discussion Starter • #1 • 11 mo ago Where would a safe place to ground a wire be in a panel behind the parking break on a 2008 f450?
meteor56 · Registered Joined Jun 6, 2015 · 217 Posts #2 • 11 mo ago The mount for the brake should be bolted or screwed to metal. Wrap the wire around the bolt/screw behind the mount.
Andrew 1 · Registered Joined 11 mo ago · 18 Posts Discussion Starter • #3 • 11 mo ago meteor56 said: The mount for the brake should be bolted or screwed to metal. Wrap the wire around the bolt/screw behind the mount. Click to expand... ok thanks for the help!!!
S Stroking it · Registered Joined Dec 2, 2018 · 377 Posts #4 • 11 mo ago Just make sure the metal is clean. You want a good ground
Andrew 1 · Registered Joined 11 mo ago · 18 Posts Discussion Starter • #5 • 11 mo ago ok good to know, thanks for the help
