Hi Guys,
A good friend of mine has an '03 Excursion Eddie Bauer with the 7.3 liter engine and it is 4X4. The power steering pump recently started making a growling noise (none like I have ever heard). It occurs when you turn the wheel to the right and to the left, but the growling is louder one direction than the other.
1) Is that an indication that that pump is going south?
2) Doesn't that run the hydroboost for the brakes?
3) The fluid looks good and clear and the level is right on the money.
The truck has about 85,000 miles on it. What should I do? Replace the pump? If so what is the approximate cost? New or rebuild?
Also, the tubes coming from the "Y" and the turbo have an oily residue on them. Do those need to be replaced, tightened? Thanks in advance. Craig
