Gutting the Exhaust Back Pressure Valve - 1994-1997 Power Stroke FAQ
2425 Views 1 Reply 0 Participants Last post by  DieselStop Content
9
Courtesy of: Gary Johnson
Remove the down pipe from the Exhaust Back Pressure Valve outlet.
Automotive tire Tire Wheel Motor vehicle Rim
Remove the actuator arm from the ball located under the Exhaust Back Pressure Valve housing by sliding the sleeve back and pull the ball from the socket.
Leg Automotive tire Human body Bumper Rim
Remove the three 5/16" 12-point bolts from the Exhaust Back Pressure Valve housing.
Remove the Exhaust Back Pressure Valve housing from the the turbo housing.
Wood Helmet Art Automotive tire Snout
Grind off and drive out the two rivets that hold the butterfly plate to the shaft. Remove the butterfly plate.
Automotive tire Wood Rim Fixture Circle
Pull the shaft from the housing.
Drive the shaft bushing out of the lower housing using an old socket (drive it into the housing).
Gas Auto part Circle Rim Metal
Drive a 20mm freeze plug into the shaft bore. I used a socket to drive it in.
Currency Money Font Circle Camera accessory
The Exhaust Back Pressure Valve housing is ready to be reinstalled. Re-attach using the three 5/16" bolts and reclamp the down pipe.
Automotive lighting Auto part Automotive exterior Bumper Metal
Unplug the actuator wires located on the driver's side, near the base of the turbo compressor housing. It is the only two-wire connecting plug.
Fluid Gas Engineering Metal Pipe
Male end of the actuator wiring connector.
Automotive tire Engineering Circuit component Electrical wiring Auto part
See less See more
1 - 1 of 2 Posts
1 - 1 of 2 Posts
