So just got off the phone with Ford Motor Company.
Background: My Kentucky Built on 11/11/2015 F350 Superduty popped a P04DB code last night.
Did some research and found the above Customer Satisfaction Program 17M04, whiched seemed to fit my issue to the 'T". Code P04DB, 2016 Kentucky build F350 from the correct build dates. "if one or more of these DTCs are present, the dealer will install a CCV collar kit on the CCV oil separator assembly, and reprogram the powertrain control module (PCM), using IDS R111.02 or Higher. "
Current: Called Ford...they said, yes yes yes meets all the criteria of the CSP, however our records indicate your truck does not fall under this Customer Satisfacation Program.
Next Step: They recommend I take it to the dealer and have them Create a Case.
What do you think?
Thanks,
Terry
Oh, picked up a Autel AutoLink AL329 at Walmart to read codes. It seemed to work fine.
T
Was there ANY explanation as to why your truck was not included in the FSA?
No, no explanation. I had them read my manufacture date, that it was made in Kentucky etc. I think the CCV is covered under the Ford Emmissions warranty however.
In that case the entire CCV and hose would have to be replaced. No big deal.
Yes, I think you may be correct. And I believe it would be covered under the emissions warranty. Thanks. Terry
