If you disturbed any fuel lines or return line caps......most likely you induced another leak. Fuel will drain off the IP and filter which causes hard starts if there is an air leak
Read....... Ford diesel 6.9 7.3 IDI read about the clear line test and air entry points....... if you do the clear line test put a verticle loop in the line(s) ... pig tail loop.
Is the starter cranking the engine faster than you can count engine rotations......
PM on the way to you........
