I am seeking help to find a source for hard to get oil fittings! I am sorry I'm not technical enough to know how to describe properly what I'm after, or what it's correctly called!
I wish to run two bypass filters on a 1992 Toyota landcruiser 4.2 litre turbo diesel engine, one a bypass sub micron wound cotton element oilgaurd type cannister and the second a centrifuge type filter!
I do not want to run these two bypass filters from the engines existing mechanical oil pump, the pressures low enough already and these engines are renowned for grabbing and spinning the big end bearings shells inside the big end caps!
I figure if I tap into the dash mounted oil pressure gauge line at the block fitting, with a T piece and bypass some of that oil thru the two separate filters mechanisms - the resultant drop in engine oil pressure & flow could be such that it triggers the crank to spin a bigend bearing shell.
Instead I want to tap into the sump and use an external electric oil pump to recirculate and clean the sump oil thru the two bypass style filters, totally independant of the engines main oil pump!
The problem I will have is in being able to tap the sump pan to get at the oil, and again - being able to tap the sump pan - to return the cleaned scrubbed oil!
I want to tap the sump pan twice - without pulling the engine to remove the sump pan, clean it and weld tubes into place to achieve this.
I have been told - there is some kind of fitting you can buy - where at oil change time - you drain the sump, use a small grease covered drillbit to drill a pilot hole where you want to tap the sump pan - then insert a self tapping, self sealing type connection fitting - that will then allow you to fit oil pressure hose with a swaged end fitting onto the fitting!
I don't know the proper name of the fitting, or where you get them, but am hoping someone before me has come across such a fitting somewhere and can point me to a link for such!
If anyone knows of any links to external 12V operated oil pressure pumps then a link also would be much appreciated!
I hope I've given enough info / description to make it clear what I'm looking for!
Please ask questions if I haven't!
Many thanks in advance!
Cheers!
Cheers!
