the clutch is at the last 1/4 inch to the floor and does not like to go into gear
reverse is the worst
fluid doesn't seem low so whats next to check?
Peddle bushings on the clutch arm.
oh and to add it will not come all the way back up i pull it wit my foot.
i went out and looked and it looks like there might be some new bushings around the peddle maybe it was done wrong?
^^^^ Those are only a couple of possibilities. Get under the dash and work the pedal. If the pushrod only moves a little bit, then it's one of the above (pedal box bushings, bushing/linkage on pushrod eyelet). If the pushrod moves all/most of the way, then the problem is "downstream". Now get under the truck and have an assistant work the pedal. Measure the fork travel; it should be at least 1/2" to 9/16". If it is less, then hydraulics are bad. If it's at least the minimum, then the problem is further "downstream" - bent/cracked fork, throwout bearing issue, weak pressure plate fingers.
Usually if the pedal stays at the floor, it's hydraulics or the mechanical bits in the cab.
