I just harpooned my 08, before I started my distance to empty said 11 miles. The tank weight was 62#, empty I think they weigh 40~45#, I figure I had about 2~3 gals. left. When I was done I added 4 gals. and went to fill up, station was about 10 miles it took 25 gals. to fill to the top.
The pump shut off without any splash back and I added about .5 gal. to get it to the rim. before harpooning I could add 4+gals. slowly after the pump shut off and the foam died down to get it to the rim.
I used my bike/atv jack to hold the tank in place, it worked great. I lowered the tank a couple inches and stuck my head in there and unhooked everything then dropped it to the floor. Before I unhooked at the tank I drained the fuel filter and had zero spill at the tank. The fuel lines don't need any special tools to take off, you just pinch 2 plastic tabs together and pull.
I also cut the filler neck down, I don't know if that makes a diff. Glad I did the mod, it will make fill ups quicker.
