So, here's the scoop. I did the "ExGaReVa" delete a year ago. I did it just to prevent head gasket probs. I have run a Hypertech programmer off and on since then with no problems. Last fall I took it in to the dealer for some warranty work. They reflashed the ECM (didn't say why) and since then my programmer gives a U0306 code. Boost is not what it was, and it surges real bad when programmed. I have left the programmer out until last week. I re-installed it and drove it on a long trip (125 Miles). Stopped to get fuel and smelled coolant. Raised the hood and coolant was around the bottle cap and all over the left side. Level was not past the new max mark on bottle.
Removed programmer and drove all week. Got on it pretty hard several times and found no coolant coming out. Yesterday I re-installed programmer and drove around town. Did not get on it hard at all and coolant is coming out again. How can it not push out coolant in stock mode, driving the $hit out of it, but will push coolant out with the programmer in driving it casual.
Talked to my local dealer and he said the programmer will leave traces in the ECM even after I remove it. Is this right? Any suggestions will help. Is it my head gaskets? It shouldn't be that "thing" on top, its been deleted over a year.
Its got 42,000 miles now. Dealer said warranty would cover if no traces of programmer. Also he said he could look at the pistons and tell if a programmer was used. Is this right?
Thanks in advance.
Thanks in advance.
