Here's some back and forth from a few years ago when Summit first started carrying the ARPs
Dave...Who makes yours(if that's not confidential) and what makes them better. The cost to me is secondary to the product recieved.
They are made by a company in CA that also make high strength head studs for the top fuel dragsters. If I remember right, they are 260k psi studs.
I'll pay the extra $$$ for the extra strength and knowing they were made by a company that has the experience they do, and designed by some Texan who knows a thing or 2 more about Power Strokes than most engineers.
I don't remember reading anyone knocking ARP. If they are a lesser quality, it doesn't mean they are junk, just lesser quality, and you get what you pay for. I'm sure ARP will sell alot of those studs at a good price for most who want assuarnce their truck will hold together.
As long as those same guys know they need a good program, regardless of what studs/bolts they are using.
You can still pop a gasket with 260k studs. I know!
After reading Clam's big post and now yours, It is causing me to think about something. It seems that many who pop a head gasket using studs also has ended up injuring a rod which eventually holes a block sometime down the road. Since the DI type studs are most used and considering they are so strong, it makes me wonder if they are TOO strong to provide a source of relief to protect the rods. Maybe the ARP studs will give up the ghost just a slight bit sooner only resulting in having to fix a head gasket instead of a whole engine. I think this may be something to consider.
Hammer
Hammer
While I understand your thinking,it's the wrong way of looking at it. Going fast means fixing weak links with better parts. What you are suggestion is installing a fusible link. My opinion is if your not willing to do it the right way leave it stock. Again understand that is the way I look at it.
I would add that going fast in a Power Stroke is not black magic the recipe is proven albeit a little expensive. The question is why are there so few fast Power strokes?
Fusible Link...EXACTLY! My point is many can't afford the high dollar rods plus labor cost and I have a hunch that maybe a weaker headstud may save the regular forged rods. When going for the EXTREME power where stronger rods are almost a requirement then the H11 bolts seem a no-brainer since the rods are no longer an issue or weak link. I think the high performance powerstroke world could possibly accomodate both sets of studs and the choice comes down to maybe which rods you are using.
The recomedation can go soemthing like this:
PMRs....use stock bolts
Forged rods....Use ARP studs
Aftermarket beefy rods...use DI's H11 studs.
just feel like buying crap studs that will break...use DPS's
Hammer
Sounds like a fair game plan,I'll leave the last one alone
