When I go to turn my parking/marker lights on my headlights turn on also. I have check over all grounds. This only happened after swapped out my fenders. Is there a ground it connection I may have missed? If so would anyone know where it is located?
Not sure if a ground would do this - and if so - I wouldn't know where to look.
However, it might be your dash (pull / push) switch has quit operating correctly?
The only way for the fender replacement to cause this would be if the DRL wiring is pinched.
