We are getting ready to go to the beach and I decided it was time to check out the truck. I found a transmission line rubbing on the fan shroud on the passenger side of the engine between the battery and the shroud. The rubber portion of the line is about a 1/4 rubbed thru.
I just wanted to pass on some new intel for you guys. I used a black 18" strap and pulled the line off the stroud. It should work fine /ubbthreads/images/graemlins/wink.gif.
