2000 F350 DRW 7.3L : HELP!
Heater just started blowing cold air regardless of the temp setting. I've replaced the thermostat and coolant in an attempt to fix it - NOT fixed, no difference!
Blows cold then hot then cold then hot regardless of where the temp dial is set and no correlation to speed / revs.
Truck warms up as normal and temp gauge reads normal.
Is there a vacuum line that works a valve that directs the coolant to the heater box or works a flap that directs air to the heater box??
thanks guys!
thanks guys!
