my heater control knob stopped doing anything but defrost or off. what do you think. is it vacuum controled? i dont see any lines off under the hood and i wanted to ask before tearing apart my dash. thanks in advance.
vaccuum leak somewhere. could possibly be a faulty esof pump. turn the car on and if the pump stays on for more than a few seconds, theres a problem. start at hubs and work your way up looking for cracks. check all the connections around the pump and tank. also pull the glove compartment down and youll see a vaccuum line there, make sure it hasnt come apart. i had the same problem with my truck, but the dealership could not get it fixed, they replaced everything. it wasnt until i swapped in some warn premium hubs and T'd off the vaccuum line to the hubs that everything started working normal again...
The pump is on the passenger side wheel well cover.
DENNY
Check behind the glove box too. There is a connection that can be accidentally unplugged.
