I replaced my fuel pump & fuel bowl w/ regulator, still only 10 psi while idling, runs and drive fine, but a pain to start.
You should be getting more than that. Are you sure there are no restrictions in the lines to the pump? Cheers!
I would hook the fuel pump up to a clean container of fuel and see what kind of pressure you get at idle. Cheers!
