Getting ready to order a DPF-r and race pipe. Dealer I am ordering it from says i should do the block off plates at least as well, I am not so sure. I have heard that the dpf-r turns the egr off in the closed position and that is all that is needed however the dealer i am buying from says it can come open from back pressure and stay open causing issues and white smoke. I have not seen this in any reviews. Also I heard that if you install the plates you get more boost, which i do not want as i just want the stock truck without the DPF. Please advise as I hope to order this soon so I can install over my time off at Christmas.
