I was driving home and my truck went into limp mode (wrench light on) and the CEL came on. Banks IQ says no diagnostic codes but says Code 42 Transmission Slippage Detected. IQ also shows transmission temperature as -68. Transmission fluid is full and clear.
It is shifting really rough and hard. Engine sounds like it is revving, but rpm's are normal.
I removed the DPF and used the DPF-R (8 months ago). Then I have the Banks 6 gun, exhaust, and CAI. Was driving on 4 power.
What is going on?
Codes that I know of...none are the one you listed:
P0102, P0103, P1100, P1101 MAF Sensor MAF concerns. MAF system inoperative may cause a transmission concern. High/low line pressure, incorrect shift schedule, incorrect TCC, engagement scheduling. Symptoms similar to throttle position (TP) failure. REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual a .
P0112 IAT Sensor IAT indicates 125°C (254°F). Voltage drops across IAT exceeds scale set for temperature 125°C (254°F). High/low line pressure resulting in harsh or soft shifts. REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual a .
P0113 IAT Sensor IAT indicates -40°C (-40°F). Voltage drop across IAT exceeds scale set for temperature -40°C (-40°F). High/low line pressure, resulting in harsh or soft shifts. REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual a .
P0114 IAT Sensor IAT out of on-board diagnostic range. IAT temperature higher or lower than expected during KOEO and KOER. Rerun on-board diagnostic at normal operating temperature. REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual a .
P0116 ECT Sensor ECT out of on-board diagnostic range. ECT temperature higher of lower than expected during KOEO and KOER. Rerun on-board diagnostic at normal operating temperature. REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
P0117 ECT Sensor ECT indicates 125°C (254°F). Voltage drop across ECT exceeds scale set for temperature 125°C (254°F). TCC will always be off, resulting in reduced fuel economy. REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
P0118 ECT Sensor ECT indicates -40°C (-40°F). Voltage drop across ECT exceeds scale set for temperature -40°C (-40°F). TCC will always be off, resulting in reduced fuel economy. REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
P0121, P0122, P0123, P1120, P1121, P1124, P1125 TP Sensor TP concern. PCM has detected an error. This error may cause a transmission concern. Harsh engagements, firm shift feel, abnormal shift schedule, TCC does not engage, TCC cycling. REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual a .
P0300, P0308, P0320, P0340, P1351- 1364 EI System EI concerns. EI system is inoperative, which may cause a transmission concern. Harsh engagements, and shifts, late WOT shifts, no TCC engagement. REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual a .
P0500, P1502 ABS Insufficient VSS input from ABS through SCP link. PCM detected a loss of VSS signal through SCP link from ABS. No transmission symptom, instrument panel, speedometer may be affected. REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual a .
P0503 ABS Intermittent VSS input from ABS through SCP link. PCM detected an intermittent loss of VSS signal through SCP link from ABS. No transmission symptom, instrument panel, speedometer may be affected. REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual a .
P0706 TR Sensor TR sensor frequency fault detected. TR sensor signal frequency is out of normal range. Only REVERSE, NEUTRAL and 5th gear detected. Engine may not crank. For gasoline engine vehicles, Go To Pinpoint Test C . For diesel engine vehicles, Go To Pinpoint Test H .
P0707 TR Sensor TR sensor circuit duty cycle low input. TR sensor signal duty cycle is below threshold, sensor/circuit electrical malfunction. Only REVERSE, NEUTRAL and 5th gear detected. Engine may not crank. For gasoline engine vehicles, Go To Pinpoint Test C . For diesel engine vehicles, Go To Pinpoint Test H .
P0700 ECM/ TCM Trans- mission control system DTC present. TCM has sent a DTC error code to ECM indicating that additional TCM DTCs may be present. MIL may be illuminated. Other transmission concerns present. Code set in ECM to indicate that there is a transmission code(s) present and technician should check the TCM for codes. RERUN onboard diagnostics and retrieve transmission DTCs from TCM.
P0708 TR Sensor TR sensor circuit duty cycle high input. TR sensor signal duty cycle is above threshold, sensor/circuit electrical malfunction. Only REVERSE, NEUTRAL and 5th gear detected. Engine may not crank. For gasoline engine vehicles, Go To Pinpoint Test C . For diesel engine vehicles, Go To Pinpoint Test H .
P1702 TR Sensor TR error. TR sensor error detected. Only REVERSE, NEUTRAL and 5th gear detected. Engine may not crank. For gasoline engine vehicles, Go To Pinpoint Test C . For diesel engine vehicles, Go To Pinpoint Test H .
P1705 TR Sensor TR sensor not in P or N positions during KOEO or KOER. KOEO or KOER not run in P or N positions, or TRP sensor circuit failure. DTC is set. RERUN KOEO and KOER in P or N position. Go To Pinpoint Test C .
P0711 TFT Sensor No change if TFT during operation. PCM has detected no TFT change during operation. TFT value stuck at some normal reading. No 5th or 6th gears. For gasoline engine vehicles, Go To Pinpoint Test B . For diesel engine vehicles, Go To Pinpoint Test G .
P0712, P0710 TFT Sensor 157°C (315°F) indicated, TFT sensor circuit grounded. Voltage drop across TFT sensor exceeds scale set for temperature of 157°C (315°F). No 5th or 6th gears. For gasoline engine vehicles, Go To Pinpoint Test B . For diesel engine vehicles, Go To Pinpoint Test G .
P0713, P0710 TFT Sensor -40°C (-40°F) indicated, TFT sensor circuit grounded. Voltage drop across TFT sensor exceeds scale set for temperature of -40°C (-40°F). No 5th or 6th gears. For gasoline engine vehicles, Go To Pinpoint Test B . For diesel engine vehicles, Go To Pinpoint Test G .
P1711 TFT Sensor TFT out of range during on-board diagnostics. Transmission not operating at temperature during on-board diagnostics. DTC set: engine cold or overheated. Warm or cool engine to normal operating temperature. For gasoline engine vehicles, Go To Pinpoint Test B . For diesel engine vehicles, Go To Pinpoint Test G .
P1783 TFT Sensor Transmission overtemp condition indicated. Transmission fluid temperature exceeded 127°C (270°F). Torque converter engages earlier than expected. For gasoline engine vehicles, Go To Pinpoint Test B . For diesel engine vehicles, Go To Pinpoint Test G .
P0715 TSS Sensor Insufficient input from TSS. PCM detected a loss of TSS signal during operation. Harsh shifts and engagements, engine rpm higher or lower than expected. No 1st, 3rd or 5th gear. For gasoline engine vehicles, Go To Pinpoint Test D . For diesel engine vehicles, Go To Pinpoint Test I .
P0717 TSS Sensor No TSS signal. PCM has not detected a TSS signal. Harsh shifts and engagements, engine rpm higher or lower than expected. No 1st, 3rd or 5th gear. For gasoline engine vehicles, Go To Pinpoint Test D . For diesel engine vehicles, Go To Pinpoint Test I .
P0718 TSS Sensor TSS signal noisy. PCM has detected a noisy TSS signal. — For gasoline engine vehicles, Go To Pinpoint Test D . For diesel engine vehicles, Go To Pinpoint Test I .
P0720 OSS Sensor Insufficient input from OSS. PCM detected a loss of OSS signal during operation. No 1st, 2nd, 3rd, 4th or 6th gear. For gasoline engine vehicles, Go To Pinpoint Test D . For diesel engine vehicles, Go To Pinpoint Test I .
P0721 OSS Sensor OSS signal noisy. PCM has detected a noisy OSS signal. — For gasoline engine vehicles, Go To Pinpoint Test D . For diesel engine vehicles, Go To Pinpoint Test I .
P0722 OSS Sensor No OSS signal. PCM has detected no OSS signal. No 1st, 2nd, 3rd, 4th or 6th gear. For gasoline engine vehicles, Go To Pinpoint Test D . For diesel engine vehicles, Go To Pinpoint Test I .
P0730 Clutch Control Solenoid or Internal Parts Gear ratio error. PCM has detected a gear ratio error. OWC clutch or clutches may have failed. Incorrect gear selection depending on failure or mode and manual lever position. Shift errors may also be due to other internal transmission concerns (stuck valves, damaged friction material). Engine rpm could be higher or lower than expected. May flash TCIL. REFER to PID P0730_Status Chart, found immediately after Output State Control (OSC) Mode in this section, for a specific failure. REFER to the Solenoid Application charts located at the beginning of Pinpoint Tests — OSC Equipped Vehicles. If other solenoid DTCs are present, Go To Pinpoint Test A . If only P0730 and/or 2700 series DTCs are present, INSTALL the appropriate clutch solenoid. CLEAR DTCs, road test. If the concern is still present, REPAIR/INSTALL new internal transmission components.
P0740 a TCC Solenoid TCC solenoid open circuit failure. TCC solenoid circuit fails to provide voltage drop across solenoid. Circuit open. Open circuit: TCC never engages. For gasoline engine vehicles, Go To Pinpoint Test A . For diesel engine vehicles, Go To Pinpoint Test F .
P0741 TCC Solenoid TCC solenoid circuit perform- ance error. Torque converter slippage detected during engagement command indicating a concern with mechanical or hydraulic operation of the converter clutch. TCC slippage when commanded on indicating a concern with the mechanical or hydraulic TCC operation. No TCC engagement. REFER to Diagnosis By Symptom .
P0742 TCC Solenoid TCC solenoid circuit shorted to ground. TCC solenoid circuit fails to provide voltage drop across solenoid. Shorted to ground. Short circuit: Only 5th gear at low vehicle speeds. For gasoline engine vehicles, Go To Pinpoint Test A . For diesel engine vehicles, Go To Pinpoint Test F .
P0743 TCC Solenoid TCC solenoid circuit failure. TCC solenoid circuit fails to provide voltage drop across solenoid. Circuit open, shorted or PCM driver failure during on-board diagnostics. Open circuit: TCC never engages. Maximum PC-A pressure, harsh engagement and shifts.
Short circuit: Only 5th gear. For gasoline engine vehicles, Go To Pinpoint Test A . For diesel engine vehicles, Go To Pinpoint Test F .
P0744 TCC Solenoid TCC solenoid circuit shorted to power. TCC solenoid circuit fails to provide voltage drop across solenoid. Circuit shorted to power. No torque converter engagement. For gasoline engine vehicles, Go To Pinpoint Test A . For diesel engine vehicles, Go To Pinpoint Test F .
P1744 TCC Solenoid TCC solenoid circuit perform- ance error. Torque converter slippage detected during engagement command indicating a concern with mechanical or hydraulic operation of the converter clutch. TCC slippage when commanded on indicating a concern with the mechanical or hydraulic TCC operation. No TCC engagement. REFER to Diagnosis By Symptom .
P0748 b PC-A Line Pressure Control Solenoid PC-A solenoid circuit failure. Voltage through PC-A solenoid is checked. An error will be noted if tolerance is exceeded. Open circuit: maximum PC-A pressure, harsh engagements and shifts. Engine rpm higher than expected.
Only 5th gear present.
Maximum PC-A pressure, harsh engagements and shifts. Engine rpm higher than expected. For gasoline engine vehicles, Go To Pinpoint Test E . For diesel engine vehicles, Go To Pinpoint Test J .
P0960 b PC-A Line Pressure Control Solenoid PC-A solenoid circuit open failure. Voltage through PC-A solenoid is checked. An error will be noted if tolerance is exceeded. Open circuit: maximum PC-A pressure, harsh engagements and shifts. Engine rpm higher than expected. For gasoline engine vehicles, Go To Pinpoint Test E . For diesel engine vehicles, Go To Pinpoint Test J .
P0962 b PC-A Line Pressure Control Solenoid PC-A solenoid short to ground circuit failure. Voltage through PC-A solenoid is checked. An error will be noted if tolerance is exceeded. Short circuit: Only 5th gear present. For gasoline engine vehicles, Go To Pinpoint Test E . For diesel engine vehicles, Go To Pinpoint Test J .
P0963 PC-A Line Pressure Control Solenoid PC-A solenoid short to power circuit failure. Voltage through PC-A solenoid is checked. An error will be noted if tolerance is exceeded. Maximum PC-A pressure, harsh engagements and shifts. Engine rpm higher than expected. For gasoline engine vehicles, Go To Pinpoint Test E . For diesel engine vehicles, Go To Pinpoint Test J .
P0750 a SSPC-A Coast Clutch SSPC-A solenoid circuit open. SSPC-A circuit failed to provide voltage drop across solenoid. Circuit open or PCM driver failure during on-board diagnostics. No 2nd, 4th or 6th gear. For gasoline engine vehicles, Go To Pinpoint Test A . For diesel engine vehicles, Go To Pinpoint Test F .
P0751 SSPC-A Coast Clutch SSPC-A circuit, clutch or solenoid failure — OFF. SSPC-A circuit, clutch or solenoid failed in the OFF position during operation resulting in HIGH pressure in the hydraulic circuit. Tow/Haul OFF or OD ON:
Normal driving mode
No 1st gear available.
Tow/Haul ON or OD OFF:
No 1st, 3rd or 5th gears available.
P0752 SSPC-A Coast Clutch SSPC-A circuit, clutch or solenoid failure — ON. SSPC-A circuit, clutch or solenoid failed in the ON position during operation resulting in LOW pressure in the hydraulic circuit. Tow/Haul OFF or OD ON:
Normal driving mode.
Temperature below -15°C (4°F) only 4th gear is operative.
Temperature above -15°C (4°F) only 6th gear is operative.
No 2nd, 4th or 6th gears available.
P0753 a SSPC-A Coast Clutch SSPC-A solenoid circuit failure. SSPC-A circuit failed to provide voltage drop across solenoid. Circuit failure or PCM driver failure. Tow/Haul OFF or OD ON:
No 2nd, 4th, 5th or 6th gears available.
No gears available.
No 1st, 2nd, 3rd, 4th or 6th gears available.
P0973 SSPC-A Coast Circuit SSPC-A solenoid or circuit shorted to ground. Voltage through SSPC-A solenoid circuit is checked. An error will be noted if tolerance is exceeded. Short to ground failure detected. Tow/Haul OFF or OD ON:
P0974 SSPC-A Coast Clutch SSPC-A solenoid or circuit shorted to power. Voltage through SSPC-A solenoid circuit is checked. An error will be noted if tolerance is exceeded. Short to power failure detected. Tow/Haul OFF or OD ON:
No gears available.
P0755 a SSPC-B Overdrive Clutch SSPC-B solenoid circuit open. SSPC-B circuit, clutch or solenoid failed to provide voltage drop across solenoid. Circuit open or PCM driver failure during on-board diagnostics. Tow/Haul OFF or OD ON:
Only 1st or 3rd gears available.
Only 5th gear available.
P0756 SSPC-B Overdrive Clutch SSPC-B circuit, clutch or solenoid — OFF. SSPC-B circuit, clutch or solenoid failed in the OFF position during operation resulting in LOW pressure in the hydraulic circuit. Tow/Haul OFF or OD ON:
No 2nd gear available.
P0757 SSPC-B Overdrive Clutch SSPC-B circuit, clutch or solenoid failure — ON. SSPC-B circuit, clutch or solenoid failed in the ON position during operation resulting in HIGH pressure in the hydraulic circuit. No 1st, 3rd or 5th gears available. For gasoline engine vehicles, Go To Pinpoint Test A . For diesel engine vehicles, Go To Pinpoint Test F .
P0758 a SSPC-B Overdrive Clutch SSPC-B solenoid circuit failure. SSPC-B circuit failed to provide voltage drop across solenoid. Circuit failure or PCM driver failure. Tow/Haul OFF or OD ON:
No 5th gear available.
Only 4th, 5th and 6th gears available.
P0976 SSPC-B Overdrive Clutch SSPC-B solenoid or circuit shorted to ground. Voltage through SSPC-B solenoid circuit is checked. An error will be noted if tolerance is exceeded. Short to ground failure detected. Tow/Haul OFF or OD ON:
Only 4th and 6th gears available.
P0977 b SSPC-B Overdrive Clutch SSPC-B solenoid or circuit shorted to power. Voltage through SSPC-B solenoid circuit is checked. An error will be noted if tolerance is exceeded. Short to power failure detected. Tow/Haul OFF or OD ON:
Only 1st and 3rd gears available.
P0760 a SSPC-C Intermed- iate Clutch SSPC-C solenoid circuit open. SSPC-C circuit failed to provide voltage drop across solenoid. Circuit open or PCM drive failure during on-board diagnostics. Tow/Haul OFF or OD ON:
Only 1st and 2nd gears available.
P0761 SSPC-C Intermed- iate Clutch SSPC-C circuit, clutch or solenoid failure — OFF. SSPC-C circuit, clutch or solenoid failed in the OFF position during operation resulting in LOW pressure in the hydraulic circuit. No 3rd and 4th gear available. For gasoline engine vehicles, Go To Pinpoint Test A . For diesel engine vehicles, Go To Pinpoint Test F .
P0762 SSPC-C Intermed- iate Clutch SSPC-C circuit, clutch or solenoid failure — ON. SSPC-C circuit, clutch or solenoid failed in the ON position during operation resulting in HIGH pressure in the hydraulic circuit. Only 3rd and 4th gear available. For gasoline engine vehicles, Go To Pinpoint Test A . For diesel engine vehicles, Go To Pinpoint Test F .
P0763 a SSPC-C Intermed- iate Clutch SSPC-C solenoid circuit failure. SSPC-C circuit failed to provide voltage drop across solenoid. Circuit failure or PCM driver failure. Tow/Haul OFF or OD ON:
Only 1st, 2nd and 3rd gears available.
Only 4th and 5th gear available.
P0979 SSPC-C Intermed- iate Clutch SSPC-C solenoid or circuit shorted to ground. Voltage through SSPC-C solenoid circuit is checked. An error will be noted if tolerance is exceeded. Short to ground failure detected. Tow/Haul OFF or OD ON:
Only 3rd gear available.
Only 4th gear available.
P0980 b SSPC-C Intermed- iate Clutch SSPC-C solenoid or circuit shorted to power. Voltage through SSPC-C solenoid circuit is checked. An error will be noted if tolerance is exceeded. Short to power failure detected. Tow/Haul OFF or OD ON:
Only 1st and 2nd gear available.
P0765 SSPC-D Direct Clutch SSPC-D solenoid circuit open. SSPC-D circuit failed to provide voltage drop across solenoid. Circuit open or PCM driver failure during on-board diagnostics. Tow/Haul OFF or OD ON:
Only 6th gear available.
P0766 SSPC-D Direct Clutch SSPC-D circuit, clutch or solenoid failure — OFF. SSPC-D circuit, clutch or solenoid failed in the OFF position during operation resulting in HIGH pressure in the hydraulic circuit. Tow/Haul OFF or OD ON:
No 5th or 6th gears available.
P0767 SSPC-D Direct Clutch SSPC-D circuit, clutch or solenoid failure — ON. SSPC-D circuit, clutch or solenoid failed in the ON position during operation resulting in LOW pressure in the hydraulic circuit. No 1st, 2nd, 3rd or 4th gears available. For gasoline engine vehicles, Go To Pinpoint Test A . For diesel engine vehicles, Go To Pinpoint Test F .
P0768 SSPC-D Direct Clutch SSPC-D solenoid circuit failure. SSPC-D circuit failed to provide voltage drop across solenoid. Circuit failure or PCM driver failure. Tow/Haul OFF or OD ON:
Only 1st, 2nd and 5th gears available.
Only 5th and 6th gear available.
P0982 b SSPC-D Direct Clutch SSPC-D solenoid or circuit shorted to ground. Voltage through SSPC-D solenoid circuit is checked. An error will be noted if tolerance is exceeded. Short to ground failure detected. Tow/Haul OFF or OD ON:
P0983 b SSPC-D Direct Clutch SSPC-D solenoid or circuit shorted to power. Voltage through SSPC-D solenoid circuit is checked. An error will be noted if tolerance is exceeded. Short to power failure detected. Tow/Haul OFF or OD ON:
P0770 SSPC-E Low/ Reverse Clutch SSPC-E solenoid circuit open. SSPC-E circuit failed to provide voltage drop across solenoid. Circuit open or PCM drive failure during on-board diagnostics. Tow/Haul OFF or OD ON:
P0771 SSPC-E Low/ Reverse Clutch SSPC-E circuit, clutch or solenoid failure — OFF. SSPC-E circuit, clutch or solenoid failed in the OFF position during operation resulting in LOW pressure in the hydraulic circuit. Tow/Haul OFF or OD ON:
No 1st or 2nd gears available.
P0772 SSPC-E Low/ Reverse Clutch SSPC-E circuit, clutch or solenoid failure — ON. SSPC-E circuit, clutch or solenoid failed in the ON position during operation resulting in HIGH pressure in the hydraulic circuit. Tow/Haul OFF or OD ON:
Only 1st gear available.
Only 1st or 2nd gears available.
P0773 SSPC-E Low/ Reverse Clutch SSPC-E solenoid circuit failure. SSPC-E circuit failed to provide voltage drop across solenoid. Circuit failure or PCM driver failure. Tow/Haul OFF or OD ON:
P0985 b SSPC-E Low/ Reverse Clutch SSPC-E solenoid or circuit shorted to ground. Voltage through SSPC-E solenoid circuit is checked. An error will be noted if tolerance is exceeded. Short to ground failure detected. Tow/Haul ON or OD OFF:
P0986 b SSPC-E Low/ Reverse Clutch SSPC-E solenoid or circuit shorted to power. Voltage through SSPC-E solenoid circuit is checked. An error will be noted if tolerance is exceeded. Short to power failure detected. Tow/Haul OFF or OD ON:
P0791 Intermed- iate Shaft Speed Sensor Insufficient input from intermediate shaft speed sensor. PCM detected an insufficient signal from the intermediate shaft speed sensor during operation. Harsh shifts or engagements, engine rpm higher or lower than expected. No 1st, 3rd or 5th gears. For gasoline engine vehicles, Go To Pinpoint Test D . For diesel engine vehicles, Go To Pinpoint Test I .
P0793 Intermediate Shaft Speed Sensor No input from intermed- iate shaft speed sensor. PCM detected a loss of intermediate shaft speed sensor signal during operation. Harsh shifts or engagements, engine rpm higher or lower than expected. No 1st, 3rd or 5th gears. For gasoline engine vehicles, Go To Pinpoint Test D . For diesel engine vehicles, Go To Pinpoint Test I .
P0794 Intermed- iate Shaft Speed Sensor Intermediate shaft speed sensor signal intermittent. PCM has detected an intermittent intermediate shaft speed sensor signal. — For gasoline engine vehicles, Go To Pinpoint Test D . For diesel engine vehicles, Go To Pinpoint Test I .
P0657 TSPC TSPC high side power supply circuit failed. TSPC high side power supply circuit failed. Only REVERSE, NEUTRAL and 5th gear available. Engine rpm at idle is about 1000 rpm when TSPC is off as a FMEM action. Power to all solenoids has been interrupted. Monitor PID tspc_flg. If tspc_flg = 1, then TSPC is on. If tspc_flg = 0, then TSPC is off. CHECK for opens, short to ground and the harness disconnected. REPAIR as required. When TSPC is commanded OFF as a FMEM action, CHECK all solenoids for correct function as listed in the band, clutch, solenoid and switch application chart. For additional information on diagnosing PCM concerns, refer to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
P1910 Backup lamp driver circuit Backup lamp driver control circuit failed. Backup lamp driver control circuit failed. No backup lamps in reverse. TR sensor is OK. REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual, and REFER to vehicle wiring diagrams.
P1124 TP Sensor TP voltage high/low for on-board diagnostics. TP was not in the correct position for on-board diagnostics. Rerun at appropriate throttle position per application. REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
P1460 A/C Switch A/C pressure cycling switch error. A/C or defrost ON condition may result from A/C clutch being ON during on-board diagnostics. DTC set during on-board diagnostics: rerun with A/C off.
Failed ON: line pressure slightly low with A/C off. REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
P1572 BPP Switch BPP switch circuit failed. Brake ON circuit failure during normal operation. Failed ON or not connected: TCC will not engage at less than 1/3 throttle.
Failed OFF or not connected: TCC will not disengage when the brake is applied. REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
P1703 BPP Switch Brake not actuated during on-board diagnostics KOER or BPP switch circuit failed. Brake not cycling during KOER or brake ON circuit failure during KOEO. Failed ON or not connected: TCC will not engage at less then 1/3 throttle.
Failed OFF or none connected: TCC will not disengage when the brake is applied. REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
P1780 TC Switch TC switch input incorrect per selected position. TC switch voltage incorrect. No Tow/Haul feature when TCS switch is pressed during self-test. RERUN on-board diagnostics and cycle switch. If concern is still present, REFER to Section 307-05 .
P1781 Four wheel drive (4WD) Low Switch 4WD low circuit/ switch out of self test range. 4WD low circuit/switch voltage incorrect. No 4WD low feature when 4WD low is engaged during self-test. RERUN on-board diagnostics and cycle switch. REFER to Section 308-07A and Section 308-07B for transfer case concerns.
P2700 Coast Clutch Coast clutch failed on or off. The PCM has detected a failure within the coast clutch system. Not all gears available.
No 1st, 2nd, 3rd or 5th gears available.
No 1st, 2nd, 4th or 5th gears available.
Coast clutch failed on or off. REFER to PID P0730_Status Chart, found immediately after Output State Control (OSC) Mode in this section, for a specific failure. REFER to the Solenoid Application charts located at the beginning of Pinpoint Tests — OSC Equipped Vehicles. If other solenoid DTCs are present, Go To Pinpoint Test A . If only P0730 and/or 2700 series DTCs are present, INSTALL the appropriate clutch solenoid. CLEAR DTCs, road test. If the concern is still present, REPAIR/INSTALL new internal transmission components.
P2701 Overdrive Clutch Overdrive clutch failed on or off. The PCM has detected a failure within the overdrive clutch system. Not all gears available. Tow/Haul OFF or OD ON:
Overdrive clutch failed on or off. REFER to PID P0730_Status Chart, found immediately after Output State Control (OSC) Mode in this section, for a specific failure. REFER to the Solenoid Application charts located at the beginning of Pinpoint Tests — OSC Equipped Vehicles. If other solenoid DTCs are present, Go To Pinpoint Test A . If only P0730 and/or 2700 series DTCs are present, INSTALL the appropriate clutch solenoid. CLEAR DTCs, road test. If the concern is still present, REPAIR/INSTALL new internal transmission components.
P2702 Intermed- iate Clutch Intermed- iate clutch failed on or off. The PCM has detected a failure within the intermediate clutch system. Not all gears available.
No 3rd and 4th gears available.
Only 3rd and 4th gears available.
Intermediate clutch failed on or off. REFER to PID P0730_Status Chart, found immediately after Output State Control (OSC) Mode in this section, for a specific failure. REFER to the Solenoid Application charts located at the beginning of Pinpoint Tests — OSC Equipped Vehicles. If other solenoid DTCs are present, Go To Pinpoint Test A . If only P0730 and/or 2700 series DTCs are present, INSTALL the appropriate clutch solenoid. CLEAR DTCs, road test. If the concern is still present, REPAIR/INSTALL new internal transmission components.
P2703 Direct Clutch Direct clutch failed on or off. The PCM has detected a failure within the direct clutch system. Not all gears available. Tow/Haul OFF or OD ON:
Direct clutch failed on or off. REFER to PID P0730_Status Chart, found immediately after Output State Control (OSC) Mode in this section, for a specific failure. REFER to the Solenoid Application charts located at the beginning of Pinpoint Tests — OSC Equipped Vehicles. If other solenoid DTCs are present, Go To Pinpoint Test A . If only P0730 and/or 2700 series DTCs are present, INSTALL the appropriate clutch solenoid. CLEAR DTCs, road test. If the concern is still present, REPAIR/INSTALL new internal transmission components.
P2704 Low Reverse Clutch Low reverse clutch failed on or off. The PCM has detected a failure within the low reverse clutch system. Not all gears available. Tow/Haul OFF or OD ON:
Low reverse clutch failed on or off. REFER to PID P0730_Status Chart, found immediately after Output State Control (OSC) Mode in this section, for a specific failure. REFER to the Solenoid Application charts located at the beginning of Pinpoint Tests — OSC Equipped Vehicles. If other solenoid DTCs are present, Go To Pinpoint Test A . If only P0730 and/or 2700 series DTCs are present, INSTALL the appropriate clutch solenoid. CLEAR DTCs, road test. If the concern is still present, REPAIR/INSTALL new internal transmission components.
U0100/ U0294 TCM CAN CAN link error detected by TCM. Loss of communi- cation with ECM. Communication loss causes high side electrical drivers to turn off. Only reverse, neutral and 5th gears are available. NOTE: A module cannot communicate with other modules on the communication network while being reprogrammed. Clear any network communication DTCs which may have been set in other modules during reprogramming.
REFER to Section 418-00 .
U0121 TCM RABS Loss of communi- cation with Brake Control Module. — — NOTE: A module cannot communicate with other modules on the communication network while being reprogrammed. Clear any network communication DTCs which may have been set in other modules during reprogramming.
U0155 TCM IP Loss of communi- cation with Instrument Cluster — — NOTE: A module cannot communicate with other modules on the communication network while being reprogrammed. Clear any network communication DTCs which may have been set in other modules during reprogramming.
Could be most anything with a proper diagnosis. I would suggest you put it all to stock and then take it in for proper diagnosis.
This to me sounds like solenoilds for wiring harness or perhaps a TCM issue.
Code 42 is a Banks code, not a Ford code. I called Banks. I ran it through a couple shift cycles and it reset. Seems ok now.
did they say what the ford code would be? Or was it maybe just a communication error?
