1 - 11 of 11 Posts
Got my injector today, and the electrical part (cap) is backwards.. can I just unscrew the cap and rotate it? help ASAP.. in the middle of this!
replaced the injector, and unplugged the harnesses to each side, and cranked it and it sounded like ****... what do I do? I am confused on how to get it going again.. Don't want to mess this engine up
· Vendor
I've seen a number of reman injectors with the solenoid backwards, I think it has something to do with the test stands that some rebuilders use. It's no problem to remove and rotate the solenoid. If the solenoid was 180° out, just rotate it. If it was rotated only 90°, you may need to rotate the armature under the solenoid as well.
Next, when you had the injector out, did you purge the oil and fuel out of the cylinder? The easiest way is to remove the glow plug after the new injector is installed, replace the valve cover with a couple bolts and crank the engine (valve cover harnesses disconnected) which will blow most of the fuel and oil out into the lifter valey. You can then reinstall the glowplug and reconnect the harnesses and fire it up.
FWIW, some people prefer to use a vacuum pump or other method to purge the cylinder. Whatever method you use, you do need to do it.
Now, when you go to start the truck, it will likely take a lot of cranking. The high pressure oil rail on that side of the engine is empty and will need to refill before there will be enough pressure to start the truck. Some people will put oil into the rail through one of the plugs to aid this process. When it does start, it will likely run like crap for a while. It will smoke and sputter for a bit, and then it just won't feel smooth and "normal" for sometimes over 50 miles until all of the air is purged from the high pressure oil system.
I hope that's helpful...
do you have a chance to call me?
Any luck??? IT is a scary thing the first time you do an injector, I have done three now. Man,, it seems like it will never start when you crank it!
And as mentioned above, ,when it does fire,, it runs like crap for a while,,,
Good luck, and hope things work out!
got it taken care of...
HUGE thanks to Dennis at ITP diesel for calling me at 9pm to talk a bit... huge relief talking to him
Thanks again Dennis
OH yea,, Dennis is one of the best. Is'nt it great that some of the guys on here will take time to call and talk to ya like that? Glad ya got it straightend out!
I was busy working 4-12 tonight,,and my "Other Job" with that Air National Guard!
Night flying this weekend.
· Vendor
Thanks again Dennis
Glad I could help!
Having had my engine apart and together and injectors in and out more than once, I found that I can almost eliminate getting oil down into the cylinder by removing the big end plug in the back end of the head. I also pull the fuel fitting off and just drain it all out before pulling the injectors.
When reassembling, I found that pulling out the forward most plug on the TOP of the oil runner (15mm wrench I think) and filling the runner from there really helps in getting the oil runner filled clear up. The dead end fuel runner is another story all together. That you just have to live with unless you install a regulated return.
1 - 11 of 11 Posts
