OK, I know others have done this, but this is the first time I have not been able to retreive it. At this point it will be faster to buy a new one than remove all the inerds. What is the size and type of o-ring?????
bret
Bret if you are refering to the FPR oring i dont have the ford # but Cat-6V9398 or JD-T77932 will fit.
Cheers Ed
Dude you rock. I'll assume that is a Caterpillar part number and a John Deere part number....am I close at least? Called nearly everyone at this point, and no luck. I'll call the JD shop now.
Bret
Right on
Cheers Ed
autozone sells a generic bunch of orings they are brown in color and will work for the fpr...currently using it on mine...they are in the area where they have all the generic one size fits all section...
Andy
Guys, after making countless calls on the part numbers given and others found in the archives, I came up empty handed. As my last resort, I went to my local CarQuest and found a green neoprean o-ring for A/C the exact size, and it only cost $1. So far, so good. I'll keep my fingers crossed and hope for the best at this point.
The John Deere shop was currently out of stock, and the Cat shop said they don't carry. In the near future, I'll pick up one from John Deere and have it onhand (or two knowing me and my fat finger).
Thanks all,
Bret
