well guys i got a prob with my 1997 f-250 powerstroke. I pulled into my drive and oil started leaking out in a steady stream from right in front of the oil pan. It had to be doing it on my way home cause there is oil all over the underside of my truck. But oil pressure stayed the same all the way home so it couldnt of happen to long before i got home. This is my first deisel and i have no clue where to start looking. And help would be great
thanks guy
There is an oil seal on front of the crank which you can replace. I replaced mine when I did my water pump. Under the harmonic balancer is where the oil seal is.
