Hi all. I'm still having a hard time getting my truck running properly.
Right now it's running but it feels like it's running on 6 cylinders. Idle is rough and I get a bad vibration when the TC locks up. I have two codes.
- Cylinder 5 power balance fault
- P0232 Fuel Pump Circuit High
The FICM was recently repaired, injector harness was probed and checks out fine and all 8 injectors were just replaced. I did some googling this morning and I have seen that a bad fuel pump might be the culprit? I'd just like to confirm a few things first.
- if my ICP reading as shown by my DP Infinity tuner seems normal would that mean the fuel pump is ok or should I check fuel pressure at the secondary fuel pump on top of the motor? I'm seeing 600ish psi at idle. Higher when driving.
- if it turns out to be a bad primary pump should i replace it with a FASS type system?
- is there a way to test the secondary pump on top of the motor?
- if I'm due for the blue spring update would my symptoms indicate that?
- other things I should check?
Thanks!
Thanks!
