Getting ready to pull out to go camping and I was checking the ATF fluid. I gues I never noticed it before but the lower hatches have a C on them and the upper hatches have a H on them. Isn't this reversed??? With the truck running isn't there less fluid in the pan to the hatches at the bottom of the stick should have the H, and when it is cold more fluid is in the pan so the upper hatch marks should have the C. I first checked before I started it and the fluid level was up at the top of the upper hatches, now with it up to temp the fluid level is at the top of the lower hatches. This seems right to me, Please help I don't want to add to much fluid to it. If I filled it up so while it was running the fluid line was at the top of the hatch marks, when it sits the fluid level would be an inch above the upper hatch marks. Thanks for the help.
KEVIN
KEVIN
