Like it says, I was on the turnpike, ran up to about 100mph for approx 2 minutes. Slowed back to about 70mph for about 2-3 minutes when truck started running really rough, wouldn't sustain 60mph. Pulled over and checked the obvious stuff... boots, oil spilled, water in oil, belts... nothing obviously wrong.
The truck runs like an old roofing truck. Only other obvious problem is the pyro gauge was stuck at 200 Degrees and wouldnt move. then went to 600 degrees and doesnt move. I looked and pyro is still stuck in manifold. I'm thinking maybe the turbo wheel came apart and took out the sensor??? I'm going to go outside and start taking things apart.
If you have any suggestions... I'll be back in about 30 minutes.
P.S. if you live out here in Loxahatchee, I could use someone out here smarter than me. /ubbthreads/images/graemlins/shrug.gif
Thanks...
Thanks...
