My truck is having issues re-starting when I have been driving it while the temps (outside air and engine/exhaust temp) get high. It only used to do this when towing for a long distance. I would have to wait about 20 minutes for it to cool down then it would start. Now it is to the point where if I drive for more than 10 to 15 minutes, completely unloaded, it won't restart for sometimes upwards of 2 hours. Obviously, this is getting a bit inconvenient.
I talked to a Ford tech and he said to isloate out the starter relay, try removing the cap and wire lead and jump it. When it was hot, nothing happened. After it cooled down, the starter turned over when jumped. So I figured it was the solenoid on the starter, which I promptly repaced. Imagine my surprise when the next time I drove it, same thing happened.
So, if it is not the relay or the started/solenoid, then what can it be? I heard someone say possibly the neutral saftey switch at one time. Is there a way to check that easily?
Any other ideas?
Any other ideas?
