Thanks in advance. I always get confused with all of the terms, etc so thought I would ask for some expert advice.
Per page 17 (bottom right of actual page) https://www.rvsafety.com/images/pdf/FordTG2005.pdf it seems I am in the safe zone of 15400lbs.???
My Truck:
2005, F250 SD, CC 6L
Door Jam Label:
GVWR 10000
GAWR 6100
I hope to pull a gooseneck horse trailer
Dry Weight 8500lbs
Pin Weight 2500
How do I figure all of this out?
Trailer payload will be +2500 if two horses + gear.
Trailer GVWR is 14500 but don't think I will ever get close to that.
Edit to add: I know you can't change the factory rating but I do have airbags on back.
Thanks in advance,
Steven
My Truck:
Door Jam Label:
GVWR 10000
GAWR 6100
Dry Weight 8500lbs
Pin Weight 2500
Thanks in advance,
Steven
