I need some information about replacing the fuel selector valve on my 1994 IDI. I know the oem pump and direct fit pumps are no longer available. I ordered one from rockauto More Information for STANDARD MOTOR PRODUCTS FV5. It was listed as direct replacement, but its not. My oem lines in the rear are nylon type without quick disconnect, and this valve is barb style. It came with a print for the electrical connector, which is the same physical connector but I don't know if the plug is electrically the same as oem on the new valve.
So has anyone else used this standard motor FSV? Are the tank feeds and returns barbed? Did you just use 3/8 fuel hose? did you drop the tanks completely or can you drop and lower a single side only? did you have to repin anything?
I plan to run 3/8 hose to and from the tanks to the fsv but with inline filters on the feeds to the valve, out of the valve to my electric lift pump 8 inches in front of the FSV up with the filter water separator.
