Can myself remove the old head studs, put in the new and tighten the news ones hand tight without removing the head? Then follow torque sequence. or does myself have to remove the heads and all to do the job?
That my friend is a loaded question.
Why are you changing to ARP studs in the first place?
The normal way is to pull the heads replace the head gaskets, then install the ARP studs.
You can try this.
Remove each head bolt one at a time, according to the torque sequence, then install a stud and torque to specs. It would be the same as re-torqueing the OEM bolts.
ie: remove #1 sequence bolt then install stud. remove #2 sequence bolt then install stud. etc.
No guarantee that it might not develop a head gasket leak. I have heard of doing this on another forum without a problem.
Just use the sequence in step #1 and #2 for each bolt, after all the studs are installed, then check the torque as in steps 3 - 4.
