Hello all. I have a International with a T444E (7.3).
I think I have a sensor telling the computer to back off the oil pressure to the injectors.
I am in the process of drilling my y pipe to tap a fitting to connect a boost gauge just to see what I have.
I have (2) sensors, one is threaded into the Y pipe that I think is a map sensor. I removed it and it looks like it senses pressure in the pipe. The other sensor is threaded in the pipe just past the air filter. The think I read somewhere that it is a temp sensor.
The truck is a dog until about 1900 rpm.
When the truck does not pull my oil pressure is about 2100 psi. at wot. When is runs decent, I have 2600 psi.
What sensors could be telling the computer to back off of the pressure until 1900 rpm?
New ICP, IPR, Injectors, CPS.
I would like to replace the map sensor but i think they are 120 bucks.
I have read that I can disconnect the map sensor (if that is what is threaded in the center of my Y pipe) and drive the truck to see if it runs better with out it connected.
My wastegate is manual, it has a rubber hose connected to the boost side of the turbo and activates a arm to open the gate. I think the gate is to open with 7 psi. I do not have a low regulator so I have a checked it yet.
Any help or guide me in the right direction would be greatly appreciated.
This is my work truck, when it does not work, I go broke. I am using the truck every day afraid I am going to damage it by running it.
The PCM tells the IPR to open/close for desired oil pressure. Do you have any codes? What's the IPR duty cycle at WOT?
