I have a 2003 6.0. The other day i was driving down the highway and my truck starting shaking real bad. after getting off the highway i had no power. at times it would not move after coming to a complete stop and periodically die. I went to one diesel shop and after i said "6.0' the guy was disinterested and sent me to another local "power stroke" specialist (allegedly). I was having contribution codes for cylinders 1,3,7. The guy had his IDS hooked up and his he said he thought it was likely a fuel pump or a copper washer being loose or something to that effect. He said i could leave the truck with him and he would perform further diagnosis, but he said since the whole side all of a sudden went down like that, then it was probably the fuel pump and that he would swap it out for the cost of the pump (factory) plus $100 in labor. So i chose to leave and i went and picked up an airdog 2 from summit. I installed the unit and the truck actually runs way better than it ever did since i have had it. The only problem i have now is that i am still getting a code for cylinder 1 contribution/balance and this thing is smoking like crazy. i get white/gray smoke at idle and stopped and upon acceleration i get black smoke. This thing rarely ever smoked, and only very lightly while the turbo spooled. now its nonstop like a freight train.
So to sum up, never smoked before, installed new pump and now it is rolling white and black smoke and still have a cylinder 1 contribution balance code popping up. i can clear the code but after about 30 seconds it comes right back.
