Need know which direction the lever for water fuel separator i changed it but didnt pay attention to way it came off also the two holes pin hole and another hole im trying find pics but no luck please help
Im rebuilding a f250 7.3 4x4 truck was wrecked also trying to source parts im not out of water yet because i got codes from check engine light put a new cps from ford on it but still have codes
Hey all,
I have been plagued with a vibration for some time now. I originally attributed it to the driveshaft and imperfect u-joint angles due to my lift, but I recently had the driveshaft balanced (including all new u-joints and carrier bearing) and the vibration persists. I have also tried...
I have to fix my up pipes do to leakage of course but before I re-install them I am wondering if anyone here has wrapped their up pipes? If so has it been good or bad?
My powerstroke will miss, then backfire through the exhaust. The injecters make a racket when the miss starts. It does it when the engine is about 25% warm. Has never happened when the engine is at running temp. It's happened at the same engine temp several times in the last week. I changed...
How many miles does your have on it. Mine is a 2002, 6 speed manual and just has clicked over 23000 miles. Always been garage kept. Still has the original tires, batteries, the plastic protective cover has never been pulled off top of the carpet yet that came on it new and 100% stock.
Hi all,
Recently been loosing 4X4.
For some reason occassionally when the vehicle is put into High 4X4 and I stop (to open a gate etc) it drops back to High 2WD, I got sick of this and started to put the vehicle into Low 4X4, now when it drops back it goes into High 4X4.
Has anyone else had...
A forum community dedicated to all Ford PowerStroke Diesel owners and enthusiasts. Come join the discussion about PowerStroke performance, modifications, troubleshooting, towing capacity, maintenance, and more!
