Happy to be here. Have a problem with my 2000 f250 7.3. No speedometer, abs light on, flashing od light, and no blinkers. Replaced rear diff speed sensor, and both front abs sensors. Any clues?
Administrator
Welcome to TheDieselStop.
I would start by getting codes read. It needs a Powerstroke capable scan tool.
The front ABS sensors don't have anything to do with the speedometer, but the signal does go thru the ABS module.
Blinkers (turn signals?) would be a completely different issue. Have you checked fuses?
It's best to post tech questions in the appropriate forum. In your case 99 & up 7.3L Engine & Drivetrain.
Welcome to the forum.
