A week or so ago I took the cover off of my HFCM to clean the water in fuel sensor and I must have damaged the gasket putting it back on. I now have a slow leak coming from around the cover. Does any one know a good place to get a gasket maby online I am going to try the International dealer today but I doubt he will have one instock. Also is there any way to stop the flow of fuel when that thing is off??
Discussion Starter · #2 ·
Ended up ordering it from Ford Stealer for about $20 plus the $30 worth of diesel I will spill when doing the change.
That particular gasket is a one use only item. As soon as you took the cover plate off it was toast. Glad you got a new one.
Take the fuel cap off before opening the HFCM. This will greatly reduce fuel loss as the tank usually has pressure in it.
I am going to do the repair this week. It is not the initial flow of fuel it is that it just keeps comeing and comeing from the tank without ever stoping. I am going to take it down as empty as I can and see what happens then fill it up at home before I procede.
