Should I be able to move the valve (1/4 turn I think) through its full range of motion without disconnecting the linkage?
Depends how strong you are, It would take a substantial amount of effort. The spring tension on an open valve will be about 10 PSI. That will get progressively higher to about 60 psi when closed. The retaining clip slides straight along the rod to unlock in. I'm not at the shop to look at one but I believe you slide it toward the pedestal to unlock it. You don't have to worry about losing it. It won't fall off the rod.
I can't get good enough grip, position or leverage trying to reach under turbo without removing other parts. I could probably move it through its full range of motion, (assuming it's not mechanically stuck) if it wasn't on the truck. I would feel a lot better if I could positively say I was 100% sure that the EBPV was not slightly closed. I may have to dig in to it to prove or disprove this. If I’m going to dig in to it, my feeling is I might as well gut it. This would probably be an opportune time to upgrade the down pipe as well. I would like to hear any thoughts people may have on this strategy. Anything else I should do while I’m there?
I wouldn't necessarily look for cooling fin damage. I would look for stuff in them blocking the airflow. One of the most extreme examples I've ever seen was an 18 wheeler that had hit a swarm of Honey Bees.
I didn't see much debris stuck in the fins. Did see where fins are slightly bent in several locations from minor impacts with foreign matter. Those fins bend pretty easy. With highway speeds of 75 mph, I don't think it would take much more than a large bug to do this. After you mentioned checking the CAC, I was thinking this could possibly restrict air flow enough to cause problems.
