Hey guys,
I've started having this horrible squeal when I turn to the right while driving down the road. If I'm driving around curve in the road right as my wheel is at about a quarter of a turn the front end will squeal. Then stop as I keep turning the wheel until I bring it back and does it at the same spot again. If the curve is such that I have to hold the wheel in that spot the squeal continues, almost sounds like a rotational noise then. Only turning right and I've determined I have be going at least over 35 to have anything happen. Been laying under the truck and can't find anything loose or rubbing so any ideas to check would be great. Also seems to be coming from the driver side. Thanks in advance.
