1 - 10 of 10 Posts
I just cleaned up the Exxon Valdez in my driveway. What initially looked like leaking coolant was diesel. It is a wonder I made it home. It must have done its deed not too far away from the house.
I traced the culprit to a hose in front of the fuel filter that is apparantly on the high pressure side cuz when the truck is running a small slit in it gushes a bucket worth of diesel in seconds.
How random is this? There was nothing to abrade it. It has what looks like threaded fittings on each end. Should I pull it out and take it to a hydraulic shop to have it matched or look into having it ordered from the stealership?
Fuel returns? There should be two of them, one from the front of each head to the regulator on the canister. A hydraulic shop should be able to fix you up. You may have to remove the a/c bracket to get the one on the left side. They are both different lengths ,so take them both when you go to get them made. Stainless steel braided with a teflon liner should just about last forever.
Here is a pic
this is the link
ooh. good thinking replacing the other one at the same time. I might do that if it isnt too hard to get out.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: angst</div><div class="ubbcode-body">Here is a pic
this is the link
ooh. good thinking replacing the other one at the same time. I might do that if it isnt too hard to get out. </div></div>
Yep, those are the return lines. You really should do both, it's just a matter of time. 5 yrs on bio and 2 yrs of wvo did mine in. I know of two others who have also had to replace them and the both run either bio or veggie.
I just went through the same thing a while back, only I had to drag it home (about 10 miles). I went ahead and replaced both sides with the Ford replacements. The part numbers are:
- LH F4TZ-9D308-A
- RH F4TZ-9B273-A
I paid $17 for the left and $36 for the right.
Discussion Starter #7
Thanks for the part numbers. That helps a lot.
Local Ford and International dont have em so will have to park for the weekend while mail ordering em.
I took a peek at the end that is behind the A/C. Ouch. That looks unpleasant. Do you have to take the A/C pump off? Any tricks to getting that end out?
It's really not that bad. Just clean everything up well before you start with superclean or purple power or the like. Remove the belt, then the 4 bolts holding the A/C compressor and just set it to the back. You may want to tie it back to keep it out of the way. Then remove the 4 bolts holding the aluminum multi-use bracket (13mm head; holds the A/C Comp, Vac pump, and PS pump in place). Once you remove the 4 bolts, just tilt the entire bracket assembly forward and there is enough room to get to that hose. Good Luck.
Wish I had seen this post earlier. I had blown the RH line back in August, and the stealership got me for $58, at which point I balked at replacing both, figuring I would find a cheaper source for the second line. In the meantime, I put that thought on the back burner... and I just blew the LH side...
LH side is only $26... should've replaced them both...
1 - 10 of 10 Posts
