Travelling back from FLA last week and stopped after 3.5 hours off of I75 for about 20 minutes. Attempted to restart truck and all it did was crank. No smoke, no konk. Just crank. Attempted several intervals of start. After about 45 minutes waiting around, the truck started right up.
I took it to a dealer in the area and after describing the symptoms, the diesel tech said he had an inkling of it being the High Pressure Oil System which requires 500 psi in order for the truck to start. He hooked it up to his scan tool and in fact that is what it was.
He shut off the truck. Started it again. Rev'd it for 3 minutes at 3k rpm and then shut it off. Still started right up afterward. He spoke about it being a problem potentially within the high pressure oil system and recommended that I have it looked at when I got home. It's still under warranty as it is under five years / 100k.
Anybody else have this problem with it just not starting with no other symptoms? It runs fine before and after this one incident.
Thanks,
Len
Thanks,
Len
