Hi All,
I am getting ready to install 3 camera's (left, right, and backup) on my 5th wheel. I will need to run three 4 conductor cables (with connectors attached) from a 5th wheel connector near the tailgate of my 2010 F250 4 Door to the center console (near the cup holders). Any hints on best ways to run, where to penetrate the cab, etc... would be appreciated.
Thanks in advance for your inputs and time.
I ran wires for KC lights where harness wires enter cab from engine on firewall between parking brake and brake. Should not be a problem, plenty of room just have to make another hole on rubber seal with screwdriver and then fish wires. If you look at powerstrokehelp.com under edas installation you see the location where they ran some fuel hose and thats the same location where I ran my wiring throug.
Hi All,
I think there are two rubber plugs on the back of the cab just in front of the box. That might be a good place for access. From there go under the carpet to the center console.
