Being in Tx we do not get too much of the cold weather. It was about 30 this morning and I went out early (lots of frost) to start her up to warm her up. No problem on the start up. Just some white smoke. I let it run for approx. 15 minutes to get warmed up. It was not really in the warm range as I started to drive. The truck did not want to shift through 1st and 2nd. Revving and bogging down then finally shifting. I had a good 1:45 minute drive into work. Even after cruising all that time at 60 mph, I would still hear a slight hissing sound in the cab, the engine would sound muffled and it was bogging down. Then suddenly it would surge back to normal accelleration. (Occurred when I had to slow then speed up again, not during cruise) When I got to the employee lot I decided to rev it up a little. Sure enough at about 1500 rpm, what I described above would happen and the tach would drop to almost 1100 or 1200. When I pressed it harder it would clear up and rev up as it should. Any thoughts? Vacume lines? Fuel geling? I am kinda stumped. Thanks, TOM
