OK... Just got to installing the new injectors(8), I had a leaker before... Now everytime I start up I get the following:
Sorry I don't have the code numbers, these are off the top of my head.
Codes stored in idm code...
8 high side open codes one for each Cyl
2 high side open one for each bank
Then after driving the following come up
Map sensor code, LOW BOOST
ICP code Low pressure
It will spit out the IDM codes after doing a buzz test, but I can hear all 8, and when I do a Cyl Contribution test, it will fail randomly on a seemingly random Cyl.
When I drive it it operates fine at low speed but if it get on it hard for a minute the boost will go to 20, then fall to 15, meanwhile monitoring the Oil pressure it goes up to 2200psi, then plummits to 700psi and the egt's shoot up to near 1000, it feels like it's under severe load at this point. to me it seems like the oil pressure is causing the fall out. It feels like it runs out of oil WAY earily.
I tried swapping the IDM into another truck and it worked fine in the other truck, I pulled the chip and got the same results, changed oil:same results. checked and checked again all harnesses to injectors, and valve covers.
What am I missing here? /ubbthreads/images/graemlins/shrug.gif
